Discuss contactor for underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
B
bennjy
Hi
I've installed the electrics for an underfloor heating system. The system has 6 manifolds each with a small pump. There is then a primary pump that pushes hot water through the system from an aerobic digester next door. I have fitted 6 contactor each using a switch wire from the thermostat to energise terminal 1 of the contactor, I have then linked from terminal one to a of the coil. I've taken a neutral to all contactor in parrelal in terminal 2 then from 2 to a2 of each contactor. I've then connected in parrelal the primary pump to terminals 3 and 4. This works fine with one stat, when it calls for heat aswell as energising the secondary manifold pump it also energises the contactor and energises the primary pump. The problem is, is that when another stat calls for heat if the other stat goes off the contactor still stays energised until all stats are off. I don't think it's latching contactor I'm sure there non latching could be wrong tho. I'm sure it's a wiring fault so any help would be great .
Can you show us a sketch wiring diagram please as it will be a lot simpler to see what you have done than to try imagine it from a long post of info'.
You will probably need relays. A sketch of what you have done will be good to see though. This diagram may help if you have a similar setup.
How do you add a photo
When you start a post the option bar over your post has a symbol with a pic of a tree, click it then click choose file, find your pic and double click it to bring it in the box than click upload pic .. you may have to wait a few minutes for it to load.
OP - Can you tell me how many thermostats you have 6? - this is easy to wire - A1 to neutral, A2 switch live from the thermostat, put a permanent live into the contactor, load side of the contactor to boiler enable. The little pumps need to be connected to A2. The primary pump to boiler enable.
Hi yes there are 6 stats. I've miss understood the diagram then I'd say. You say a2 switched live then a2 neutral? Would it be possible to do a little scetch sorry to be a pain
OK - repeat this at each manifold.
From a local switch fused spur bring Live & Neutral into a JB (small adaptable box), connect live into "2" connect the primery pump/boiler enable to "1"
Connect A1 to Neutral.
The switch live from the thermostat connect to A2 and also connect the live for the local pump to A2.
Make sure all the electrical feeds to the manifolds are fed from the same heating circuit.
Thanks for that. The way I've done it is to energise the coil with the switched feed then terminal 2 to primary pump but I guess that is enabling the contactors to stay latched once switched until all feeds are broken. I've mounted the time clock on a adaptable box so all cabling and contactors are in there. I've used 5 core tho so it's easy enough to do there
Are there any valves?
Reply to contactor for underfloor heating in the UK Electrical Forum area at ElectriciansForums.net
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
