Discuss Cooker switch in the UK Electrical Forum area at ElectriciansForums.net
J
jimzxcv
Hi,
Got to move a cooker switch down a couple of feet from current location, no problem there, but when the new cooker comes, it will have a light switch above it. (Currently no cooker, although the switch is there). Moving the light switch is going to turn a small job into a pretty big one.
advice please ?
Jim
Hi,
advice please ?
Jim
Seek professional help by asking if someone here near you can take a look and give you a quote.
I always hate getting called to move a lightswitch as more often than not it is not as simple as the homeowner thought. One time i was called as a homeowner had a new door hung but opposite of how it used to open so now the switch is behind it. Turns out there was no rcd to protect the cable as it will be chased in <50mm without mechanical protection, no main bonding and no earth to the lighting. Needless to say i did not get that job
A classic example of the customer not thinking about the ramifications of their new cooker....... As a spark this isn't difficult is it?
So bonding? RCD's? you know the normal stuff!
Reply to Cooker switch in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
I have bought a cooker with a ceramic hob which has a warning light to show that the top is hot, the light goes out when the hob cools down. I...
Hi, With respect to the cooker switch only. If I moved it 400mm to the left by extending the T&E from its original position using crimps, then...
Hi I am seeking help and best practices to achieve below tasks. I am not across regulations hence will appreciate best approach to achieve below...
