Discuss Crabtree elcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
you must have been to specsavers. i thought it was 0.5, but not clear enough to be sure.
As defined by 14th edition of wiring regs it is a current operated earth leakage circuit breaker [now known as an rcd] as opposed to a voltage operated earth leakage circuit breaker which are no longer permitted since the 15th edition. It is rated at 500ma.
A voltage operated earth leakage circuit breaker is generally coloured black and are slimmer than an current operated earth leakage circuit breaker.
A voelcb will also have 2 x earth wires connected to it (normally the earth terminals are on the bottom face in the middle), 1 x from the consumer unit and 1 x going to the earth rod, whereas an current operated elcb will not have any earths connected to it.
Reply to Crabtree elcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
4K
Some electric tankless shower water heaters have inbuilt ELCB. Are they better than Triton water heaters which don't have it ? and does Triton...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
Hi all, Been asked to do EICR on thatched property for insurance purposes, however they will want all C3 codes rectified. Haven't seen it yet but...
