Discuss CU Circuit Schedule in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Amp David
Mentor
I know it is possible to buy circuit schedules to stick on or near the CU unit, but do you have to use a dedicated schedule, or would a copy of your test results placed in a plastic wallet do the same job.:confused:
IMO its best practice to stick schedule in or near CU. We took over a brand new property and the plastic wallet you suggest is there but empty. We had to chase the builder to get all the documentation for everything in the house etc etc.
Chris
Print off your own circuit schedule and place adjacent D.B. together with test certs.
I can send you a template if you wish
Just photocopy the circuit details/test results pages of the cert.:)
That's what we do copy circuit details onto self adhesive A4 paper and stick to inside of DB doors no chance of it getting lost. (Unless somone steals door of DB)
Reply to CU Circuit Schedule in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
