Discuss depth of chase and rcd protection..... in the UK Electrical Forum area at ElectriciansForums.net
kevyn
If the cables are chased more than 50mm into wall what is the requirements for rcd protection?
Have missplaced the big red so can't check just now.
It is not possible for me to rcd protect new cables in extension without ripping up rest of the house. It is feed from an old 3036 rewireable board.
Cables at a depth less than 50mm require RCD protection.
So your chase is going to have to be deeper, probably 60mm.
Or you could use some galv condit as mechanical protection.
I think the building regs state depths of 3rd of the thickness of the wall for vertical chases and 6th for horizontal chases so gonna have to be quite thick walls to get away with it
unless he finds underfloor/in wall IR faults, shared neutrals, lack of bonding etc.
Reply to depth of chase and rcd protection..... in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hello Need to replace a distribution board in the next few weeks to allow for more circuits to be installed in January. Existing is a TT system...
I'm doing a college design project and need to choose a suitable range of circuit protective devices for the whole contact. I've chosen and...
