Hi.
Just replaced the second door microswitch in my Sharp R959 combi/microwave oven - there's three there in total; the first went a couple of years back, and the third is still ok. That's not a problem - it's been great machine for many years, and has only ever required a new TT motor, oven bulb and the two m'switches in all that time.
Anyhoo, when looking for a replacement m/s this time, I found a few variations of the Omron D3V, and checked the specs of them all. The Sharp original was a D3V-16G-1C25, and the one I replaced it with (for reasons of not having to buy a multipack) was a D3V-16-1C25. Looking at the specs of each, the ONLY difference I can find between them is that the non-G switch has a contact gap of 1mm whereas the 'G' (original) is only 0.5mm. (See link below).
(1), even 1mm seems tiny for a contact gap! What is it actually referring to? And (2), if it is the open contact gap, isn't 1mm better than 0.5mm anyway?! If anything, it would seem to me to be a 'better' spec? Or am I missing something?
Many thanks for shedding any light on this - it seems a bit strange to me.
https://docs.rs-online.com/1956/0900766b80dbf2c9.pdf (see item 2 in 'Model Number Legend' under 'Ordering Information')
