Discuss Dishwasher timer issue in the Electrical Appliances Forum area at ElectriciansForums.net
S
Simon
Hi,
We have a dishwasher that when it starts then there comes a pause for about 6-7 minutes before it starts working. It ends each washing program with satisfactory results.
I can't remember as if it has always had such a pause or not, thats why I wanted to ask you who have the knowledge if it is normal for a dishwasher to have such a pause, or it could be a sign of eventually its timer need to get replaced.
I have looked at the wires around the timer and all seems fine, no sign of corrosion or damage.
Thanks in advance
I am not sure, should it generally take 6-7 minutes to heat up the water?
If you're in a hard water area, then it's entirely possible that the heating element has furred up over a period of time. This could slow down the water heating time as the heat transfer becomes less efficient, try running a good de scaling solution through the machine. Once you've done that, run a solution of 1 Jiff lemon & 2 table spoons of White vinegar through on the hottest wash.
"Washing machines live longer with Calgon" - just saying.
Do you hear water go in then the long pause? If so then water getting up to temp like being said.
Reply to Dishwasher timer issue in the Electrical Appliances Forum area at ElectriciansForums.net
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
I have Curry's Essential tabletop dishwasher model CDWTT115 for nearly five years. Earlier this year my machine have stopped running during a wash...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Having to wire around a messed up output for a month or so. Some sort of program corruption is keeping the central lubrication system from...
Hi All, Thankyou in advance for your help I have a block of 5 stories with a staircase timer already installed in a 3 wire connection setup. I...
