Discuss Does anyone know what this is? in the UK Electrical Forum area at ElectriciansForums.net
Mellow
Trying to decorate for my elderly mother and found this in her bedroom. The other side of it in the joining room is the 2nd pic
It looks like a switches fuse outlet for maybe a panel heater before the wet radiators were put in.it might be worth getting an electrician in to have a look and either remove them safely, disconnecting them from any supply, or changing the faceplate to a socket and moving it slightly so it can be used.
it's a fused connection unit. (FCU). you need to ascertain if it's still powered up or is it redundant. best advice is to get a local electrician to check,/isolate/make safe.
Thank you. Just got scared when we seen the other side of ot
2nd pic looks like something out of Tom & jerry.
Reply to Does anyone know what this is? in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know what this is found when removing old mirrored wardbrobes
Hi all - my daughter recently bought her first house and found this electrical device in the loft. Any idea what it is? It appears to be...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Does anyone know what the cable in the picture is called? Or anything about it? Labelling on the outside is “E SPC Electric Cable 600/1000v” Its...
As per title. Does anyone know what this symbol means? It’s on a IP rated outdoor light and there’s nothing in the instructions to say what it...
