Discuss Door loss of power intermittent in the Auto Electrician Forum area at ElectriciansForums.net
Hi everyone, Help please. Power to my passenger door keeps going off, no windows, lock doesn't work, wing mirror indicator stops work, then they will all work for 10 minutes then all goes off again for days on end 😩😩 anyone had a similar fault?
You might be lucky and be able to see it is broken.
Often in the loop between the car body and the door
It's also possible that the problem is with the wiring loom to the driver's door. The functions of the passenger door are often operated by controls on the driver door, some of which are duplicated on the passenger door and the driver's door loom normally suffers much more flexing over the years than that of the passenger door.
Depending on design, there might also be multi pin plugs and sockets in the 'A' pillars, where the door looms plug in, and these can suffer from corrosion if water gets in.
Thanks Brian, I will have a look at drivers door.
Reply to Door loss of power intermittent in the Auto Electrician Forum area at ElectriciansForums.net
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Recently my RCCB keeps keeps tripping intermittently. It can happen between several hours to few days when a trip will occur. During the trips, no...
4K
