Discuss Downlight Cover / Insulation Advice in the UK Electrical Forum area at ElectriciansForums.net
spoodge
Hi I'm currently boarding out a small section of loft space for storage, there are two layers of insulation covered by standard chipboard loft boarding.
Underneath the insulation there are 3 low voltage down-lights for the bathroom, basically what I need to know is how much, space if any, I need to leave around them and if I need to use the fire proof covers I've seen advertised.
I've covered the insulation with board , so concerned about heat buildup, not sure what these low voltage lights give off.
Here's some 3D renders I made of the project, I always do this to scale so I know exactly how much material I need and can experiment with layouts.
larger Images are available here....Loft - Album on Upload the image directly to the thread for some reason this forum doesn't re-size posted images.
The white tube is an extraction pipe from the bathroom.
Grateful for any advice..
tia
http://i.Upload the image directly to the thread.com/BugtJ2vl.jpg
http://i.Upload the image directly to the thread.com/DAPU5Fhl.jpg
http://i.Upload the image directly to the thread.com/v3oN4P0l.jpg
http://i.Upload the image directly to the thread.com/wdaomnpl.jpg
It would normally come down to the manufacturers instructions but no doubt these are no longer available.
Low voltage (12V) halogen down lights get very hot and need air circulation above and around them to dissipate the heat.
generally if you leave 100 mm around and 50 mm above and there are no flammable materials near them then they should be OK.
Ensure the insulation does not creep back into the space.
The metal down light joist covers can be useful but the price mounts up quickly.
what he said. ^^^^^^. also i'd advise swapping halogens for LED if halogens are currently fitted.
Great , I'll just leave sufficient gap, there's less of a heat loss issue with the boards on top.
Thanks for the advice.
I think they are LEDS, they don't get that warm.
I generally fit these fibre loft caps, both for halogen and LED fittings:
https://www.tlc-direct.co.uk/Products/TLALC274.html
A bit pricy, but they just sit on the ceiling, so easy to install. You can then fit the loft insulation back around and over them without the risk of overheating.
Still worth it, even for LED, as it shortens their life if they get too warm.
Wow, a tenner for a fireproof plantpot?.., surely there's a cheaper workaround / substitute ? ...still, this is for my mums loft...for my peace of mind I think i need to fit something.
Reply to Downlight Cover / Insulation Advice in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
I'm currently refurbishing a room and in the process adding some internal wall insulation. The wall has been stripped and my electrician has...
