Discuss Earth Leakage Clamp Meter...Why do I need one? in the UK Electrical Forum area at ElectriciansForums.net
Is this earth leakage meter anything like my Amp clamp?
What I can’t understand is what is the difference between some of the £300-500 dedicated earth clamp meters and £50-100 clamp meters that measures down to single digit milliamperes, and these are not total crap.
the expensive ones are more accurate due to the lower resolution, but my cheapo thats resolution of 1 mA will do what i need. coupled with a hammer, can find any fault going.
thought as much might get a cheap one and see how much hammer it gets before looking for something more accurate.
I own a earth leakage clamp meter.
Useful to test background leakage .... Especially prior to doing a cu change and doing initial testing with rcd tripping.
I can see the CU Change bit as useful at quote stage to be fair. That's the first post that's given me any reason why I may actually use one.
Don't understand what you mean by "initial testing with rcd tripping"?
Well, I use it to check the amount of back ground leakage .......... because it can help to know if you have high back ground leakage .... then something small will tip it over.
I do this along with the standard RCD tests - to see what level the RCD (s) is / are tripping at.
Reply to Earth Leakage Clamp Meter...Why do I need one? in the UK Electrical Forum area at ElectriciansForums.net
Has anyone here got experience of doing a soil / earth resistance survey for the design of a large-ish site? We might be looking at a fenced area...
I'm new to this but stuck with an issue, so I'm looking for some help wherever possible. I have just completed a rewire, which I have a potential...
I recently borrowed one of these to diagnose an earth leakage problem, and it was very useful: 560 60A Digital Earth Leakage Clamp Meter -...
4K
While waiting for a reasonably priced earth leakage clamp meter that will do both AC and DC leakage, I find myself asking the question which is...
5K
Morning, Customer has a intermittent trip which I am trying to locate. 4 circuits on rcd. Two rings , cooker and hob and one I cannot find...
