Discuss EICR Coding - Super Rough Kitchen Rewire in the UK Electrical Forum area at ElectriciansForums.net
I know which is why I was hunting for a reg which it specifically broke.
Would you be happy to leave this without a code on an EICR?
The EICR was requested to highlight the faults with this 'rewire' because it looked so rough.
Live conductors in an enclosure not being isolated by same switch? Best I can come up with is a labelling reg (514.11.1) but technically its not the same enclosure.
Why would two different live conductors in one enclosure not be allowed? Millions of two way lighting circuits in houses have this set up, what about a mulit gang grid switch in a warehouse?
sorry crappy explanation on my part, but reg 514.11.1 requires a label in each position where "...there are live parts which are not capable of being isolated by a single device."
Bit overboard to apply it to a domestic setting I agree, so can you confirm that you would be happy to leave 'as is' with no coding if you did this EICR?
Reply to EICR Coding - Super Rough Kitchen Rewire in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
