Discuss EICR Limitations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
TJC1
When doing EICR, what you people normally put for extend covered?
Also do people have a general list of things you put as Limitations when testing? IE no moving furniture, no portable appliance,
That would completely depend on the situation, type of installation, operational limitations etc. For instance, are we talking about an unnocupied 2 bedroom flat or a large factory running a 7 day 24 hour production schedule ?
Do a few different situations.
1. Is small offices only 2/3 rooms
2. Domestic, normally 3/4 bedroom. Normally furnished, but sometimes empty
Generally in those listed situations limits would/could be placed on:
cables concealed within the building fabric
inaccessible areas
circuits that cannot be isolated for operational reasons
But usually limitations on inspection and testing should not be looked for and avoided if possible, especially in these situations.
My standard limitations are: no dismantling of the building fabric and no lifting of floorboards.
that is printed on my certs before i fill them in. sometimes i'd like to be able to enter a lim..... "xxxxx was not tested because the client is an arse", but i don't think that would go down well with the suits. :19:
Reply to EICR Limitations in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Had an enquiry where the installation (commercial) is relatively new and client has requested a condition report. Probably 80-100 circuits plus...
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
On a Eicr on agreed limations of iinpections what do you normally put And what percentage do you test at..
When doing an eic, does anyone put limitations for existing wiring within walls and under floors and you’re not able to check them? Or what do...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
