L
lokesh.dee
HI
I have a MCC panel it is showing KW reading for each phase L1,L2 and L3 are 4.7KW,4.0KW and 4.2 KW repectively. the energy consumption for 2 hours was 16 Kwh.how come it is possible
my doubt is my load was stable for 2 hours with 10-15% variation i should be 8-10 Kwh for 2 hours why it is 16??do we have to consider sum of 3 phases power??? or average of them??
If you are reading KW on each phase then for 3Ph it the sum of the phases. Just be sure you are reading KW or KVAr on all meters.
Reactions: 1 person
thank you!!
I am sure that it is K W . if it is sum it should be 24KWH for two hours right??!! because the load was stable for 2 hours
there is energy meter installed in the panel i wanted to compare the kw and kwh reading so i have asked this generel question
tell me in generel total KW of a motor = L1KW + L1KW + L1KW
if it is the case where we can find supporting theory??
You need to take efficiency and power factor in to account. The KW rating of a motor is the output at the shaft.
Reactions: 1 person
While a 3 phase motor running which is connected to particular panel kw reading is showing only for one phase l 1. My doubt is on energy meter why that is showing only one ohase kw ??!!!
electrical energy calculation in 3phase
lokesh.dee,
lokesh.dee,
