Discuss emergency lighting diagram in the UK Electrical Forum area at ElectriciansForums.net
P
peek a boo stoo
Need some help if anyone can, i have been trawling the internet and forums to find a basic wiring diagram of a non maintained emergency lighting circuit with a key switch incorporated. so far i have found nothing.
I DO NOT NEED IT EXPLAINING THATS NOT THE ISSUE.
i find everything falls into place with a drawing.
Can anyone help???
Cheers
HI MATE
If you type in the search bar im sure you will come across some diagrams people have kindly posted for people !!!!!
I have definately seen some on here before !!!
On I keep putting on here, using 3 c + E system. Hope this helps
OP I understand what you mean its easier with a diagram as they are simple to interpret but why not try drawing one yourself rather than searching high and low ... it will help you develop a useful skill for future as the more you try it the better and easier it becomes to take things from you head to paper.
as darkwood said try drawing it yourself. when i was training i was encouraged to draw out new circuits that i came across to help me understand them. i still find a couple of minutes spent drawing a problem circuit helps when fault finding.
In terms of connections there are two ways of doing it - you can have the keyswitch just cut the permanent feed, leaving all the lights on but the emergency lights in emergency mode, or you can have the keyswitch cut all the live feeds so you can easily see which emergency fittings are illuminated.
Again, it'll be slightly different if you're wiring it in singles.
A Few issues with the cut live method Adam....you put the building in darkness, and in this day and age of no win no fee suing. I personally would not recommend. Em light should be identified by number, makes id easier on testing and replacing....saves telling the poor spark to replace the light, by the staircase next to the lift, outside the md`s office. Alot easier to say replace light fitting number 6
IIRC the last time different methods of wiring emergency lighting were discussed it got pretty heated.
I agree the 'cut live method' isn't the best in all situations, ie turning nearly all the lights off in an officefull of women can cause them to panic and moan, but if you can get into a room to do the test when it's unoccupied it's easier to see what's going on if only the emergency lights are on.
If possible the test should be done during daylight hours when there's enough natural light for safe evacuation, although if the emergency lighting system doesn't do that then it needs improving.
well worst cases I have come across are nursing homes....this is another problem area....id numbering is the best way.
Reply to emergency lighting diagram in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all, Just wondering if anyone would have a diagram, or know where I can find a link to a diagram, of how emergency lighting is wired, from...
4K
Hi all Got a question regarding HMO compliance. Visited property today for landlord looking to apply for an HMO license for one of their...
Two lighting circuits covering various communal areas on two floors of a HMO. The non-maintained emergency lighting that covers those areas is on...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
