Nov 8, 2010
44
My customer, who has a lot of downlights (12v )throughout the house would like them all changing to mains led. I pulled a couple down to check the connection - JB in place so I could cost accordingly. I have noticed that all fittings including ones with habitable room above are not fire rated.
Am I obliged to change to fire rated? In essence I'm removing transformer and changing lamp holder.
I would always fit fire rated, even when I'm not obliged to. I usually find little or no difference in price between fire rated and non fire rated fittings, so struggle to find justification to use a lesser protected fitting.
Fire rated lights are necessary when the above rooms are a different property ie. flats. In a house there is no obligation as I understand it.
I would normally if im fitting from scratch ,but I dont want to incorrectly inform customer that she has to replace whole fitting. If I can use existing fitting and just change lamp holder to gu10 then its cheaper for her.
just replace the lamp holders and lamps. removing the transformers as you go. ssimplesss.
retro fit Gu10 LED's are old tech now ! erghhh
fit the Haler, JCC or ELD proper LED fitting
he's dealing with a common or garden customer, not the NHS who love wasting other peoples' money.
Fire rated downlights
Security Alarms, Door Entry and CCTV (Public)
Luminous,
telectrix,
