Discuss Fluke T5-1000 Electrical Tester WTF! in the UK Electrical Forum area at ElectriciansForums.net
This may be the dumbest post ever but I've just bought this Fluke T5-1000 and I have absolutely no idea how to use the openJaw thingy. Is that thing a wind up!
I get how to use it with the probes.
For instance should'nt I be able to measure amps being used on an appliance by putting its cable through the Jaws....or am I completely off track.
HELP!
Yes. The normal way to measure current is to put the line conductor (or neutral) through the jaws only, not a flex containing line, neutral and cpc for example.
same as with a normal clamp meter, but no jaws to open. 1 conductor only at a time. ( remember to set amps on the dial.)
well, i can't get my thingy in the jaws, but i prefer to use it on cables anyway.
I can get mine in the jaws but there's a bit of a loose fit, will this effect any readings I get?
always just use the jaws like a clamp meter. 1 core only between the jaws.
No wind up. It's a question. I guess not up to your usual high intellectual standard but a question none the less. However after looking at the T5 more it does have warning labels on its input which would indicate you can't do what I tried to suggest above. I really like the T5 but boy would it be even handier if I could get the clamp into tighter spaces.
Reply to Fluke T5-1000 Electrical Tester WTF! in the UK Electrical Forum area at ElectriciansForums.net
For sale Fluke T5-1000 with original belt pouch and Fluke voltage tracer pen ( it was a set ) this has never left the house just been sitting in...
I will start by apologising to @westward10 as he will have had to take time out to move this thread to the correct section. I am terrible at...
6K
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
Hi Everyone, I'm new to this forum and am hoping someone can give me some advice, as I'm absolutely clueless when it comes to these things. I'm...
Recently I lost my Fluke T5-1000 tester and rather just replace it with the same I was wondering if it is worth paying the extra for the T6-1000...
9K
