- Reaction score
- 52
I have had a good search for this information but can't find it anywhere not even in my on site guide 17th edition.
So imagine you have a CU with 10 MCBs but no RCDs. You decide you want to install an RCD.
You do your max load and diversity calculations for each MCB circuit and you come out with 10 current values that will invariably be less than the rating of the MCBs.
How do you use that information to decide what size RCD to install assuming the MCBs are all in the same bus bar?
Do you add up the max demand and diversity currents? The current ratings of the MCBs? Or is there a formula similar to the max demand and diversity rules for MCBs that you deploy to the RCD size calculation? EG: All of highest current value, 80% of next highets and so on.
Is this calculation something that can lead to a decision to split the CU if a single RCD can't cover the entire unit?
