Discuss Frequency without voltage in the UK Electrical Forum area at ElectriciansForums.net
tank
Could anyone shed some light on what might be going on here, before I cut a trap in the laminate to find out. I have a dead socket on the end of a 2.5mm cable of unknown origin. L-E L-N N-E all 0 volts. Insulation resistance between the ends all 1000M Ohm. No continuity any conductor back to the consumer unit. I even insulation tested the ends via a long lead back to the board bars, 1000M ohm. Yet my glow stick lights up by the cable and when attached my mft reads 0v at 50Hz.
Because it doesn't draw any current from the cable, the volt stick can light with even a tiny amount of capacitive inward leakage current caused by the disconnected section running next to live cables or being terminated in the same accessory as live circuits. However the available current is too low for the MFT to measure correctly; although its input resistance is high, it is not infinite and it pulls the voltage down to near zero. There might be enough left for it to sense the frequency though.
Reply to Frequency without voltage in the UK Electrical Forum area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
M
Hi Guys I purchased some of the above online around 3 weeks ago, They are a fairly new product, very usefull as you can change both colour from...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
