Discuss Frost protection in attic/loft in the DIY Electrical Advice area at ElectriciansForums.net
lecky_bob
Hi,
Last year we had a burst pipe in the loft - made a heck of a mess!
I would like to try and get some frost protection up in the loft.
Originally I was thinking of some trace heating cables but having been up there I can see there are a lot of pipes! They are all insulated with 20-30mm foam.
Rather than trace heating cables (which would be a huge job) I was thinking of a space heating approach. Putting in a thermostat and a fan heater of some sort - just to heat the space when the temperature gets low.
Thoughts on this approach? Recommended products?
Most products seem to talk about 5decC for cut in but that is a bit high I think, it could get colder before the insulated pipes have an issue?
I’m amazed that insulated pipes froze .....
Was the property empty and heating off at the time ....
Properly lagged pipes shouldn't freeze.
Trying to heat the roof space is a waste of time and money.
Spend the money you would spend installing heating on relagging the pipes fully with quality insulation.
Post a picture of the loft and pipes
Interesting comments guys - and just stopped me buying a space heater!!
The insulation is a mix of foam (20mm) and old fashioned wrap cloth type. By the sounds of it, redoing it all with quality 30mm would be a better course of action?
Recommendations for best quality insulation? I will get out and buy some
You might as well burn £50 notes to keep the loft warm mate than try fan heater as a said relax the pipes
this will do in most cases. we had -15 deg. winter of 2011/2012. nothing froze. upload_2019-1-3_10-56-6.jpegcheap and easy fit, as the stuff is slit, just cut and slip over pipes. comes in various diameters.
another way would be to do proper insulation of the attic. bin all the itchy-poo on the attic floor and fit 3" kingspan between the roof rafters, leaving 1" space between kingspan and roofing felt. bloody expensive though.
As usual Telectrix, the forum sage, has spoken wise words.
If the pipes are close to the floor level then 300mm of insulation will also help.
a whole foot of itchy-poo scratchy covering where you can tread and cooking cables.... philistine. :eek::eek::eek:.
Cut the lagging tight.
Tape the joints and a couple of wraps of tape down the split length to hold it together.
Spend time fitting it neatly.
Lag any tanks as well
soon be a thing of the past if we are to believe the tree hugging climate warming doom mongers. we still have the gulf stream as the EU has not been able to work out how to divert it to the Baltic. (if they could have made a directive, they'd have done it by now). so stoke up the coal fires, warm the planet. no more frozen pipes. ssssssimplesss.
Hi,
Can't you get a frost /pipe stat installed on your boiler?
I can't see that really helping - whereas decent insulation on the pipes in the loft would be a far better investment.
I can definitely see it helping,aren't they designed for use in situations that the op described?
Not convinced - especially as his pipe lagging sounds out of date.
Our heating has a frost stat on it - set to 9 degrees ........... but its an internet based system to the lowest setting is 15 degrees ........so the house never gets too cold - and we don't have any pipe work / water in the loft either ........
But the op does have pipes in his loft and he may decide to install a frost and pipe stat that is suitable to his particular requirements. Im genuinely interested in why you think a frost and pipe stat won't help avoid frozen pipes?
just fit a blanket on top of the roof. it works on my neighbour's car windscreen. never gets froze. :D:D:D.
It might help .......... but the OP's admission that his pipe lagging is poor - so that's where to start and its relatively cheap, and is definitely DIY ...
When I read the original post and he said he already had insulation, personally I would then have thought a frost/pipe stat
would be a good idea but I take your point that the insulation that is already there might be virtually useless. I was just confused why you originally said you couldn't see a frost/pipe stat helping but you have subsequently said it might help,which I do agree with
That would only keep the heating pipes warm, which will probably already be warm as the heating is likely to be on in freezing temperatures.
It won't help the cold water mains or any other pipes in the loft which are more likely to freeze.
Reply to Frost protection in attic/loft in the DIY Electrical Advice area at ElectriciansForums.net
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
At our church, one of the things I've done is sort out the heating wiring (as best I can for now). The schematic is as shown below. The theory...
