N
NewbieRuffy
HI Guys.. hope everyone is well! I need some advice please on a garage circuit, i am still pretty new and I am hoping to use this job i am about to describe as one of my NIC jobs to get registered.
So, a friend asked me too look at a fault in the garage where when he switches the light on the whole house trips (single RCD). I didnt even attempt to find the fault, or should i say the whole garage wiring was one big fault. Spurred off RFC in the house, 5 double sockets and then fed off the sockets the lighting circuit!! Anyway i suggested that its totally redone correctly. So I'll rip all the current wiring, reduce sockets as he never uses garage anyway and run straight from the CU. Now the garage is attached to the house and the CU is on the same wall (in the house), nice and easy to run cables to garage. The CU (as mentioned) is only on single RCD and all circuits protected by it. There are 3 spare ways. I thought of a couple of options:
1. Add 2 CB's 6A for lights in garage, and 16A for a radial circuit in garage.
2. Run 6mm cable to garage and add a 2 way, RCD protected CU, though from what i gather this pointless because of discrimination? is this right? and the fact the the house would trip first?
3. Im not sure about this one but could i do the same as option 2 but without the RCD in garage CU and use a RCBO at main CU?
Couple of questions, do i have to use SWA to garage if i decide on additional CU in there? from main CU to garage CU will literally be less than a meter?
I read on some other posts earthing maybe effected?
Any help/advice as always would be much appreciated.
