C
carljbrooks
Hi All,
I have recently moved into a new build house and we are looking to install garden lights. We had a electrician round and he said that he would spur off a socket (on ring main) on the rear wall via a RCD connection unit and then into a IP rated enclosure on the house wall. From the external junction box then run SWA cable at a depth of 500mm to the position of garden lights.
I just wanted to check that this is the correct way he should be doing it and was to current regulations.
Carl
Carl
