Discuss Gardtec alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
S
sparkie-leeds
Hi All,I have a gardtec alarm, when I set it all well and good, when I come in the entry exit zone it beeps for me to turn the alarm off, unfortunately I didn't make it this certain time, (nothing to do with the beeeerrr!!!!) the alarm went off, but strange thing is that the bell box did not ring outside, it rings outside on any other zone, can any one shine alight on this please, help would be appreciated.
Depending on which panel you have, Gardtec tend to use different user codes to set area zones, suggest reprogramming your code to set all zones, or reset panel to factory default....enrty exit zones will always sound and time out.
I know some make of panels, when you part set a system it will only ring the internal bells, set as standard, which you can change ( i found this out the other week with a veritas panel !)
Did you perform a full set when you went out?
possibility is that the alarm went into loud tone internal sounder as you were running out of time. if the system does not require a reset and does not log an alarm activation, then that will be the case. try the same again, but wait a bit longer before entering the code. see if the outside sounder activates then.
Reply to Gardtec alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi all, Requesting your help please! I know this is an old system but has been working amazingly for 7 years! I had an engineer out who done a...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Hi, My alarm system is a Texecom control unit (Premier 64-w) + Keypad + Sounder, and is using the wired zones 1-4 only, with no additional...
