• Thread starter Deleted member 112398
  • Start date
Search for tools and product advice,
Discuss Help - Glow Worm Flexicom 30CX in the The Welcome Forum area at ElectriciansForums.net
Hi. Just moved into a new house and have a Glow Worm Flexicom 30CX that was recently serviced and has been working fine. However tonight the Drayton Digistat Wireless RF601 controller got wet (don't ask) and there is no sign of live on the controller main panel. Hot water still comes on fine but I can not get the heating to come on now. Couple of quick questions please...
1. Will the Drayton digistat wireless controller possibly come back to live when it dries out or do I need to buy a new one (they seem to be around £45).
2. Can I turn central heating on at all using the boiler at all? I don't think I can but worth asking.
Any help appreciated! Thank you.
Is the Drayton programmer battery powered?
Theres so many different ways the heating can be wired and controlled, I don't want to say the wrong thing.
If it is, and there's no cables to disconnect at the stat - take the batterys out, take the stat off the wall and leave in a warm place like an airing cupboard. 24 hours, stick in new batterys and see what happens. Might need to be paired with the switch at the boiler again.
Is it a system boiler? (do you have a hot water tank) or is everything direct off the boiler.
Depending on the system, there might be a zone valve on the water pipes that can be manually switched with a mechanical lever on the valve itself to bypass the controls and bring on the heating
Did exactly what you said regards the controller and drying it out. Worked a treat and reconnected to main boiler fine. Brilliant - thanks so much. What took you a couple of minutes to type probably saved me £80. Thanks - much appreciated.
My bills in the post
It’s by no means a 100% solution. You may have problems with it in the future if the electronic innards got fried.
Get yourself a new stat anyway. And watch where you’re splashing the water
Reply to Help - Glow Worm Flexicom 30CX in the The Welcome Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
