Discuss Help to find Best cable reel ??? in the UK Electrical Forum area at ElectriciansForums.net
hi. I’ve recently had to skip my trusted cable reel of nearly 10 years. I’m struggling to find anything similar and can only really see the cheap reels which have no weight to them and just fall over. What ones would you guys reccomend ?
Actually I have seen a very nice reel made up of steel conduit. Maybe you could make your own DIY reel? Two Ninety degree boxes and a couple of U bends with a steel conduit across the boxes. Forget how he did the rotating bit but sure you can find it on Utube? See how I did that;)
I remember back at college they had 20mm conduit cable spoolers, they were actually quite good but kind of annoying to put the drums of cable on.
I have one of the cheapo flimsy generic ones, not so bad if you screw it to the floor.
I made a steel conduit set years ago. 20 mm in two right angle boxes, with a 20mm into a 25mm as the spool. It folds down to nothing to fit in a bag and does up to 10mm t&e and singles.
Or racketeers with anything as the spool. Even had three 240mm’s on a bit of scaffold pole on them the other day
Reply to Help to find Best cable reel ??? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m an industrial electrical engineer apprentice working at a wastewater treatment plant, I’ve been really enjoying the job which I’ve been...
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
I’ve recently moved into house and had an electrician out to install some new lights and shaver point in an en-suite. Problem is that the house is...
Hi guys, I never really come on here to be honest, but I thought I’d get the opinion of a world of unknown to me electrical contractors because...
