Discuss Help with installation methods please. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sjm
Currently doing a rewire on an old house. Loft has 50mm joists at right angles to a large central joist 200mm. So I can clip cables along the centre of the loft with no problem. Using installation method 101 it would seem that I can lay the cables out to light fittings between the joists on top of the plasterboard ceiling. I'm using 1.5 T+E so insulation on top should not be a problem.
Normally I would fit extra runner boards to clip the cables to but I need to get the 1st fix done asap so the quickest allowable method is required. Your valued opinions would be greatly appreciated.
Thanks in advance.
Steve.
Reply to Help with installation methods please. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Hi everyone. What's the correct reference method for cables (2.5mm t&e 32A? ring main) clipped to wooden joists between the ground floor and...
Hi My 4 bed 2 storey house was extended 2 years ago and completely re-wired, but I am having to upgrade the insulation and board out the loft...
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
