dave30
well hear i am asking for your help again i really don't know what i would do with out this site and the people who answer the questions i ask
so thanks for all you help
- Which of the following is classed as 'Minor Work'?
a) Adding extra lighting points to an existing circuit
b) Installing a new circuit to supply a fused spur
c) The replacement of a consumer unit
d) The re-wire of a socket outlet circuit
- Approved document A-P give,
a) statutory methods on to carry out building work
b) ways in which to carry out electrical work in dwellings
c) statutory methods on how to comply with the Building Regulations
d) practical guidance on how to comply with the Building Regulations
- Which of the following is non-notifiable work under Approved Document P?
a) Adding a new lighting circuit
b) Adding a new socket from a ring final circuit in a kitchen
c) Adding a new socket from a radial final circuit in a living room
d) Adding a lighting point in a bathroom
-Where material change of use is required for part of a building, such work should be carried out as necessary to protect all the building from spread of fire. This statement would apply to a building of a height of
a) 5 meters
b) 10 meters
c) 15 meters
d) 20 meters
a) 5 meters
b) 10 meters
c) 15 meters
d) 20 meters
