Discuss Hi guys, new member here needing advice on workshop wiring. in the The Welcome Forum area at ElectriciansForums.net
I will check my earthing type but I think it's either TNS or TNCS.
Regarding the 10mm cable it runs through my loft space and where it connected to the original shower isolator it will be now going into a junction box and connecting to a black round double insulated 10mm 3 core cable that runs to the workshop.
As my workshop is only 3.4M the black 10mm will be dropped through my soffit and clipped to the house wall for approx 1.5M's before it goes into the workshop.
Where will you be putting the JB, Will it be MF, why use 10mm2 flexible cable, never seen double insulated cable, seen cable that is insulated with a PVC outer sheath though.
This is not swa cable is it ?.Not sure what you are using as a junction box that would be rated 40A+ or will take 10mm cable outer sheath included.
I have just had a look and we have a PME TNCS system.
The 10mm round cable is just 3 core with a PVC outer so sorry I called it double insulated.
The cranes and straddle carriers I work on usually use this type of cable on motors and heavy draw equipment and PVC singles in trunking for PLC/ control gear etc.
The junction box I was going to use is like this one:-
Click 60A Junction Box 3 Terminal (WA222) - https://www.electrical2go.co.uk/60a-junction-box-3-terminal-i-brown.html?utm_source=google_shopping&gclid=EAIaIQobChMImPSovvzU1QIVbL7tCh0zbwVpEAQYByABEgIrA_D_BwE
Can't see anything wrong with that screw it a good foot up on one of the roof trusses so it don't get trodden on & as said try to get cable above roof insulation so not to de-rate.
Reply to Hi guys, new member here needing advice on workshop wiring. in the The Welcome Forum area at ElectriciansForums.net
Hi guys, A car showroom / workshop brand we do work for has asked us to modify a few things in the workshop. One of them being to implement...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi Guys, Looking for a bit of advice for my kids power wheel car. I have a 24v to 12v converter which I need to use for the steering motor as...
Hi Guys, im new to the forum and looking forward to reading some of the questions and advice. . I have been asked to install a safety device /...
I finished my Electrical Fitter/Mechanic Apprenticeship in late 1998 as a mature age student while working at an Electrical Distributor across our...
