Discuss High Voltage AC and DC in the UK Electrical Forum area at ElectriciansForums.net
To do with how far the electricity will arc in a nutshell.
Edit: miss understood the question as to why the values were different. The above is why this level was chosen.
is that root 2 in decimal? :sunglasses: 1000 x 1.414. where does x10 come in?
but that's peak V, not peak-peak for that it's x2, (no 10's in hrere)
Does this vary depending on the type of nutshell? Would it arc further in a walnut compared to a peanut? :)
Reply to High Voltage AC and DC in the UK Electrical Forum area at ElectriciansForums.net
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Is Voltage the Resonance of Electrons? (Either in AC or DC-please describe each one seperately if needed)
Given the advancement in technology and the high amount of potential DC in electrical systems. An AC RCD that won’t work, invokes so many further...
Hello right off the bat I'm a novice with a little better understanding than most(father was a electrician) but I am not an electrician. I'm...
Hi, We are working on a Solar installation in the UK and have been asked to replace the string cable terminations, 6mm² yellow insulated ring...
