Search the forum,
Discuss Hob combustable zone and socket outlet in the UK Electrical Forum area at ElectriciansForums.net
Hi all
as the picture attached you can see the location of the hob and the metal socket to the right, now the gas fitter has gone to commission the gas and has said he can't do it as the socket is within 150mm of the hob
now looking at the picture , i agree that it looks a little close and looking at it more there is loads of room to the right , however the owner is a little concerned that his freshly tiled back splash will need damaging if it needs to move
any comments welcome , i want to do the correct job , however if the gas man is just being a jobs worth and following recommendations rather than regulations then that would be useful info
That ring is designed to have a wok on it which will direct the heat and flam'age in that direction which is a shame.
I of a mistake is how it looks, I agree - decorative blank and a return visit.
Could it be under Reguation 512.2.1
Also any female in the kitchen is to be not allowed 1.8mts within any kitchen appliance.......
corrected that for you. it's females that stick knives in toasters, ram 25lbs. of washing in a 12lb. washer, pile dirty dishes into the dishwasher till there's none left in the cupboards, put pies on metal plates in the microwave........... and onandonandon.
corrected that for you. it's English females that stick knives in toasters, ram 25lbs. of washing in a 12lb. washer, pile dirty dishes into the dishwasher till there's none left in the cupboards, put pies on metal plates in the microwave........... and onandonandon.
Corrected that for you, hot Polish women don't do things like that........ ;o)))))))
Looks like that socket was there long before the hob was.
Ideally needs to be moved but the plumber also needs to come up with a the number from a relevant publication to back up his claim.
P69 of the sparkles guide to building regs shows diagram with cooker switch 100mm distance from hob but says must be positioned so it is not necessary to lean over hob to operate. Can’t find reference to sockets though. 300mm for sockets from sinks and draining boards.
OK, let's think about this...a plumber says he can't connect something because he thinks an electrician has got it wrong...but what has that got to do with it?
Plumber fits his stuff, job done. He's "commissioning the hob", not commenting on the electrics, surely? He should carry on, and make a comment on his sheet that suggests he is unhappy with the positioning of the socket.
Oh, how many people are killed every day because there is a socket outlet quite close to the hob?
I'm fed up with being told what to do...
even my wife is less strict!
haha. mine's OK, she's of Polish parents.(this wasin answer to SWD, before i saw pirate's post).
Breakout originally in the old Atari days, then a new lease of life as Arkanoid much later.
i wouldnotfit a socket above the sink drainer anyway. it's a splash hazard and encourages customers to use a kettle on the drainer. (NHBC diagram #2).
Thanks for that .......... don't remember seeing that before ......... shame its not in BS 7671 - as it would clear things up and remove ambiguity...
I don't suppose that would be in the remit, maybe in an appendix as rough guidance, but even then people would quote it as law.
By putting it as suitable for the location and influences it puts the onus on the designer to think about the possibilities and work appropriately.
Since it's a gas guy complaining, he should justify it and specify a bs7671 reg, gas reg, or information from the instructions of the socket or hob to justify. There should be a technical support line to help if he's needing assistance.
Specifying everything in the regs is a fine balance between taking away flexibility and giving people clear guidance that only needs a ruler to comply.
Reply to Hob combustable zone and socket outlet in the UK Electrical Forum area at ElectriciansForums.net
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi all, Recently a mate had a new kitchen fitted, he's gone for an induction hob and pyrolytic oven, no gas at the property. At 1st fix a single...
4K
