Discuss Hot tub wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I'm awaiting an inflatable hottub, plug and play although I'm worried that having it of my house ring main will overload the circuit, I want to have it on all the time, I also want to keep the price down so I don't want to rip up floorboards and damage walls. My CU is above the front door and I have acquired a reel of 6mm cable, would it be acceptable to add a 32a breaker, drill straight above my front door then use plastic trying all the way around the house into the back garden which is about 20 metres, aswell as adding two WiFi cameras along the way, killing two birds with one stone, for the cameras I will spur of the radial circuit into a fused spur, is this the best way to do it without doing a cowboys job and spuring off a near limit circuit. I would rather not buy armoured cable when I have plenty of 6mm twin and earth around. Cheers
plug and play hot tubs are generally 2.2kW, i.e just under 10A. the biggest load is the heater which cycles on/off with it's thermostat. unless you Ring circuit is already heavily loaded, it won't cause a problem on the ring. cameras usually get their 12V supply from the location of the DVR using a ELV cable, which itself is powered from a plug in PSU.
I'm just wondering if I have like the washing machine, the cooker, the tumble dryer, the fridge, the tv and the hottub all on one circuit would that not overload it, the hot tub will be a 1500w eco heater aswell so even better think that's about 7 amps. Forget about the cameras for now then and they are WiFi cameras all they need is plugged in I think although they have not arrived yet.
[automerge]1595916564[/automerge]
I'm just wondering if I have like the washing machine, the microwave, the tumble dryer, the fridge, the tv and the hottub all on one circuit would that not overload it, the hot tub will be a 1500w eco heater aswell so even better think that's about 7 amps. Forget about the cameras for now then and they are WiFi cameras all they need is plugged in I think although they have not arrived yet.
cooker on the ring, or separate circuit?. how many socket circuits, i.e. separate ring for kitchen?
you need to allow for diversity. even with several appliances on simultaneously, not all will be drawing max. current as heating elements cycle on and off at different times. e.g. washing machines and dishwashers. tumble dryers are on heat most of the time though, but even they have thermostats. if you could get a local sparks to measure the current when all appliances are running, you'd be surprised how low it maybe.
I can test that mate I am an electrician just trying to get everything sorted while I'm away working so I can jump on it when I get back, so I'll just run the the spur from the downstairs sockets
Reply to Hot tub wiring in the UK Electrical Forum area at ElectriciansForums.net
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
