J
Josh Ekins
Hello all, I've had a chap come round to talk about getting some panels on the roof before the tariff changes in Jan. I've signed up and am using the cooling off period to consider if I can afford it.
He's planned to put 10 mono panels on the roof (he said the mono panels produce more than the polys), it's only a few degrees off south and we're in Bristol, which is sunnier than most places in the country.
The calculations were done using minimum, guaranteed projections. He's guaranteed us a £600 per year return. That's £311 from the feed in tariff, £60 export and £229 "energy used" (which I assume means savings on our energy bill).
Some of the numbers he gave us are 30* inclination, 10 mono panels, 30* from due south, it's a 2.65kw system x 942 "kwh/kwp (kk) from table" x 1.00 shade factor = 2496 output kwh/year
The loan repayments are about £100pm.
So £600/12 = is £50pm
Which leaves us with a short fall of £50pm.
However, he also told us that these figures are a guaranteed minimum, that in reality the panels will produce considerably more than that. He also said that the calculation is based on poly panels, not the monos which we'll be getting. So can anyone give me an idea based on their own experiences of how much money the panels will likely produce? Our energy bill saving I suppose is a constant at £229, but how much would the current £60 export and £311 feed in likely be in reality? Not using the minimum statistics and using mono panels?
Sorry for the newbie questions, I'm very grateful for your help.
