For the level of work they carried out Im now assuming Building Control should have been involved?
He's just written his name then underneath the builders name who hes carried out the inspection for then underneath that his signature. Theres no name of any company.
- - - Updated - - -
I cant seem to upload the pdfs, any ideas?
This should allay your anxiety
Q
Who is responsible for making sure any work complies with Part P
Ans
You are. By law, all home owners and landlords must be able to prove that all electrical wiring meets Part P, or they will be committing a criminal offence.
Local authorities can make homeowners or landlords remove or alter any work that doesn’t comply with the Building Regulations.
Read this
England and Wales : Electrical Safety Council
A rewire with change of consumer unit requires building control notification. If the person doing the work is a member of a self certification scheme, that you can check on the competent person register, then he can self certify the work and building control are only receiving paperwork.
If he is not a member of a scheme then Building control should be inspecting and testing as the work goes along, although if the workers are qualified building control may accept their qualifications and paperwork.
- - - Updated - - -
On the single signature form from BS7671 the electrician who signs it is certifying that the work has been designed, installed, inspected and tested by the signatory, it is not signed for anybody it is signed by somebody.
You could check if the builder is on the competent persons register or search for the electricians name but I am not confident you will find them.
You may need 15 posts before you can upload, not sure.
There is a website The Competent Person Register that lists all companies who a registered to work in many fields, including electrical installation, search for the company name on this register and if they are there then you have some reassurance.
The forms can be in many different formats however they should be based on model forms in the wiring regulations, you can get copies of these from the IET as a pdf download look on the right hand side half way down at model forms choose the top one. The form you should have received initially is an "Electrical Installation Certificate"
once the work is notified or approved by Building Control you should receive a building regulations compliance or completion certificate.
Yes ive looked at the pdf model forms here and it is very similar. This is all we have had (4 pages) nothing from Building Control obviously as they were not informed.
What would you do now, apart from telling the builder I am going to Building Control, and where do I stand in regards to not paying him the final payment due to all of this?
Cheers Richard
Ive checked the competent person register but he doesn't show up, surprise surprise.
So you are saying that if he has signed it he must have installed it too, is that correct?
Contractually if the cert is not a valid one then the job has still not been tested and certified. In addition the local authority probably have not been informed of the work (which you should receive another part p certificate of compliance for). Therefore the job has not been finished and you have no requirement to pay the last payment. He would not have a leg to stand on in a court of law.
Building control (if they were informed) have 30 days from the date on the single signature certificate to get the building regs certificate to you.
If neither the builder nor the electrician nor any overall company are registered with a self certification scheme then it is worth asking the builder how notification to building control was made and when you would expect the Building regulations completion certificate.
Unfortunately if work is being done that requires building control notification, legally it is the householder who should ensure this is done, but in practice it is almost always the tradesman who actually does it for smaller jobs.
If you go to building control and say that this work was done then they may say that they would need to inspect it (for a fee) and, if dangerous, could ask for it to be redone, sorry.
Cheers Richard
Read the declaration just above the signature that should explain what he is signing for!!!
If there is no mention of a scheme or who they are registered with , then they are not approved to carry out domestic work . Go back to your'e builder and tell him your'e going to local authority building control, with the certs ..
sorry...but this is horse sh!t...
and again HOW MANY MORE TIMES???....you dont need to be a member of a scheme to carry out installation works on domestic properties....full stop!!
its about competency...thats it!!
either the person ordering the work can notify LABC themselves...or the electrician can do it....either on a direct with LABC basis.....or through a scheme provider...if they are a member of one...
I have said that, in slightly different terms.
I understand Richard but if we didnt know about informing Building Control from the start and the builder never informed us this may be the case how are we supposed to know that? It seems very strange that he can basically do as he wants and then its left with us to sort out even when he has issued a bogus certificate which surely is illegal in itself as the person named on it has never been to our property!!
Why don't you just use his outstanding payment to get it inspected then at least you know what your dealing with
Glenns parks right! Im sorry to say it olmanjon but i think youve been had by cowboys. Dont feel bad though. ive helped a handful of people this has happened to. My advice would be find yourself a trusted, well established electrician and explain what has happened. Also contact building control and explain the circumstances. BC WILL NOT TAKE ANY ACTION AGAINST YOU FOR NOT NOTIFYING ABOUT RENOVATION. Their usally quite sympathetic and helpful.
I hope the standard of work they left you with isnt to bad and will not need ripping out.
Good luck
