Discuss how to convert Positive Pole to Negative in the UK Electrical Forum area at ElectriciansForums.net
You might need to rephrase the question with the correct terminology, or you’re going to get strange answers.
An AC supply changes from positive to negative 50 times a second , (in UK) so are you asking how to change a line to neutral?
Saying you’re from the Moon also won’t help with answers
Yes, you understood correct my PMA (Alternator) has 3 AC +ve output A, B and C. to my understanding you need +ve and -ve to run appliances when the PMA moves I have to use Bridge which turns AC to DC and I get both +ve and -ve from three (A, B, C) poles but then I have to use a converter to get it back to AC.
I want to eliminate the converter and bridge from my circuit and would like to know if there is a device or circuit which I can use to get AC +ve and -ve straight from PMA output Poles
Typically alternators are three phase, so they have 3 terminals that are all AC and spaced 120 deg in phase angle apart. The use of a suitable 6-diode bridge rectifier then results in a moderately smooth DC for charging batteries, etc.
If you use just two of them (any pair) you will get the usual single-phase AC (similar to a domestic outlet). However, by ignoring the 3rd one you are not going to be able to safely get as much power out without the risk of overheating the windings.
You have not said what the voltage is from the alternator, or what voltage you need for the load. A transformer will change the voltage, but you have other issues:
  • If the supply is not designed as a generator to substitute from the grid it may well have a very different frequency and that can cause problems. You cannot easily convert frequency, and the easy way is to do what you already do (covert to DC, back to fixed AC).
  • On a similar theme, the output voltage may not be regulated (and / or may depend on the DC output) so you can have problems of widely varying voltages.
TL;DR You need to provide more details.
I suggest if you do find a way you should patent it then auction it to the highest bidder. IMHO
It's a fact that (due to phasing) L1+L2+L3=0V and a very hot alternator.
Reply to how to convert Positive Pole to Negative in the UK Electrical Forum area at ElectriciansForums.net
Hello, I have a fairly big property and to get power to the house, there are several metal poles with the cables running along them. I had...
This is wiring for a car speaker, everyone says that the polarity doesn't matter if it's only 1 speaker but does for multiple, this one has purple...
Hi Guys, Looking for a bit of advice for my kids power wheel car. I have a 24v to 12v converter which I need to use for the steering motor as...
I am looking for the connector for this rotary position sensor. The sensor is originally normally used for an EZ-GO golf cart as the throttle...
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
