Discuss how to reduce 6volts dc to 3 volt dc ? in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bigwhyte
i have a 6 volt system on a 175 cc motorcycle. I would like to know how to wire my tail light so that the LED tail light goes from 3 volts dc to 6 volts dc. (3 votls clearance 6 volts brake light) or is there a better way to do this ? thanks in advance
what do you mean by 3 volts clearance?
my first instinct is just to use a resistor, but i would have to know what you mean
You may need a wiring diagram ,you must you have a forign bike so anythings possable ,check it out ,before you burn it out ,either that or rip the whole loom out and design your own custom job ,that works
good luck
Reply to how to reduce 6volts dc to 3 volt dc ? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi guys. I was a commissiong technician before I retired. Hardware and software industrial automation. Miss the work but not the endless travel/...
Hi, I'm looking for a bit of advice on a volt drop query we have in our office. I'll explain the scenario and I would really appreciate any...
I want to operate 3 lighting set up using metal halide lamps for studio works or cinematic projects in the future. as of now i have got two...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
