Discuss Interesting 4 core flex ... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Came across this today...
When fault finding a boiler control change ....
This photo is between the outlet plate and the tank stat. The same flex has been used between the controller and the boiler....
I must say I'm a bit puzzled by it - and wondered if anyone here had seen it too.
I don't really want to start disconnecting it ...
Hence the s/wire(with the tape at a guess)
I have seen that before,has it got anything between the outer sheath and the cores?
It was a while ago,but it used to come from RS components,and was used in mobile cabins and the like.
It isn't odd.
OK they were debating the cable that some people thought was a bit different, or something that they hadn't seen before, relating to the colours of the cores within the outer protective sheathing, apparently to some it was something worth mentioning, obviously in your opinion not worth a mention.
Reply to Interesting 4 core flex ... in the UK Electrical Forum area at ElectriciansForums.net
Is there such thing as a 2 Gang flex outlet plate, changing an existing heating system to a nest so no need for the programmer however it is by...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road. 2 - Reason for call, heating not...
I have a spare 2.5mm 3 core flex cable. Can I use it for an outdoor light? It will be connected a junction box that's already supplying...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
