Discuss Interior lighting switch in the Lighting Forum area at ElectriciansForums.net
Most likely the link between Switch 1 and Switch 3 (short red wire) is in the wrong terminal - it should be taking the permanent live from switch 1 to switch 3 (or possibly the other way), but is likely effectively in the switched live terminal at one end.Hi all
In UK
I have a 3 gang light switch. Switch 3 only works when switch 1 is turned on. Can anyone help to fix this!?
Switches 1 and 3 operate a single lighting circuit. Switch 2 is on a 2 way circuit and works fine. Switch 1 works fine.
Thanks in advanceView attachment 61092
i think that your feed to switch 3 is coming from the switch 1, if on the switch 1 you change the link to the com you would be okHi all
In UK
Reply to Interior lighting switch in the Lighting Forum area at ElectriciansForums.net
