Discuss internet slow on more than one device is on in the Computer and Networking Forum area at ElectriciansForums.net
J
justanoob
just wondering if anyone can help my internet speed is quite slow but when I try to surf with more than 1 device the other one takes ages to load takes that long I get bord waiting and use mobile instead I have tried everything changed internet provider, replaced router just in case anyone need to know Im currently using a netgear n600, I also tried hard wired into the router Ethernet but still same. I tried different comps coz I thought it may be the comp but still same rang the old net provider before i left them and they said its not their end and same with current provider, so im running out of ideas to try now hope some one can help cheers in advance.
I have tried this it only tells you the speeds etc not why im not able to surf on more than one device it says the checker says:
download speed 6.85 mb/s
upload speed 0.370 mb/s
ping 359 ms
im not too sure If this is ok or what but
cheers again for replying
The ping time seems quite high
Do you know what speeds / bandwidth you should be getting or are paying for
That is not fast at all, and ping is high
but i would not expect it to slow down even more between two computers unless you are both trying to download or play on line?
Very occasionally I get it as well. Apart from ping, the speeds are similar to mine. Sometimes ( and this is a theory) the router appears to allow two devices with the same IP address. In theory this should not happen. When I reboot the router and re-log back on it usually clears it.
have you got dropbox or other programs on that computer constantly connecting?
download netlimiter 3, its free and will show you how much every process is using and allow you to limit/block access.
dropbox/teamviewer slows my gaming to a crawl ssometimes
nothing running as I have tried on various computers and devices so this not the issue and I was with virgin then moved to plusnet who im currently with.
It is worth checking whether the computers are speaking to each. There may be so much chatter on the network that it causes other traffic to deteriorate. That is one possible reason why this occurs only when more than one device is connected to the network. That also may explain your observation that they are not downloading anyting in the background.
To see if that is the case, download the free Wireshark packet capture utility. Run it on your network adapter on both machines and close down all your programs. Of course, every machine is different but if you only a hundred or so packets a second on each machine then that's not bad. If it sends thousands a second then it would mean your networking gear is taking a hit.
Reply to internet slow on more than one device is on in the Computer and Networking Forum area at ElectriciansForums.net
I recently sold my Renault Trafic as it had done 214,000 miles and I also wanted something more economical. I bought the Citroen Berlingo LWB. A...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
