Discuss Is my boiler wired right? in the UK Electrical Forum area at ElectriciansForums.net
To be fair to the OP (see post #7) he is using a Fluke voltage tester, a lot more use than a chocolate fireguard.
It's not a 'proper meter', but safer as a basic tester than a cheap multimeter!
To be fair to me, i was using it to test whether the power was off, so basically using it for what it's made for. Just noticed it was giving voltage on what should be the switch live.
I also accidentally called it current above - i don't know what else to call AC but it flashes up AC when voltage is detected. I figured since it's 50v AC i could call it 'AC current' since AC is alternating current. Is there some other terminology i should be using?
My apologies, thought it was a non contact volt stick. I won’t admit I was wrong because I’m too stubborn, I just wasn’t totally right.
Which new reg is that and how are you supposed to know about them unless you read all 6000 pages of wafle
As a practising electrician, you should make it your business to be aware of any changes in the regulations, which are not waffle, but are designed to improve the safety of electrical installations. There are update courses, and numerous YouTube videos outlining the changes.
Reply to Is my boiler wired right? in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
