R
rob121
Evening All,
Posted a thread on here a few months back reagrding not being able to find a bonding clamp on the water supply. Basically im doing my NIC DIS, ive done one main job (new build) and second job was going to be adding an additional circuit at home (single socket under consumer unit :wink5. From the unit theres 2 bonding cables (10mm), one runs to gas meter, access to connection, verified etc. Seperate cable goes to water supply but cant access clamp as its all been boxed in. I cut a few holes to try and find it but no luck (last attempt resulted in hot water pipe being nicked, another job to sort out now!). I can see the cable run down the wall next to the boiler then gets plastered over and obv goes behind boxing. My question is, can I cut the bonding cable and join it to a new length with a new clamp on the supply pipe? As far as im concerned you CANT and bonding cables have to be one continious length. I just want to check because it would save me a lot of grief. The joint would be accessible as it would be in the boiler cupboard. I was thing something along the lines of a earth terminal block?
Any suggestions would be much appreciated,
Rob
Rob
