Discuss Keyed Spurs in the Canada area at ElectriciansForums.net
M
mcgrathe
Can anyone guide me. I am looking for a spur for a ventelation unit in a devlopment that has a "secret" switch..i.e a keyed switch. To allow maintenanve to switch off for servicing.
I had searched for a product to no avail...anybody out there know of any?
I have seen them mate Contactum do one, if you have no luck with that i suppose you could put in a fused spur with a key switch above it.
Reply to Keyed Spurs in the Canada area at ElectriciansForums.net
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
Hi There, Just wondering if anyone is aware of any devices that automatically preserve vehicle 12V battery life by breaking the circuit once the...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
DIYer question. I have a 32 amp supply going from consumer unit in garage to kitchen. It supplies an induction hob only. The cable is easily...
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
