Discuss Klix roses in the Australia area at ElectriciansForums.net
C
Cj24
I can't quite get my head round wiring through klix, if in a room I have a pir which will be off a 4 pin klix and 1 em light obv off a 4 pin and a non emergency off a 3 pin how do I go about wiring it off a key sw?
live through Key sw to A pin on 4pin greg PIR Live to A Pin Load to Sw N to N E to E take your switched side off the back of greg in 3core+earth pin A is your Perm feed loop it through 3 pin gregs the switch wire neutral and earth wire as normal
Sorry I don't understand that, if it's via a key sw then there is goin to be a perm feed and a sw feed at ya first 4 pin klix which is my pir so do I put my sw in live and perm in aux then perm out of aux into aux on my next 4 pin which is emergency and just live to live to live of both 4 pins and 3 pin and will this work?
Just checking another thread n having a think about this If the key is turned off then all lighting would go out mark would
CU to A
Ato key sw
Key jointed in greg box to perm on 3 core
3core n earth to 4pin Sw A N 3pin the perm feed into Loop??
Reply to Klix roses in the Australia area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
I have just removed a rather expensive CD system from a house. I did explain to the customer that I thought it was worth quite a bit, but they...
