Discuss led downlighting wiring help in the Lighting Forum area at ElectriciansForums.net
J-b
hi I just wondered if anyone could help at all I’m installing led down lights in my bedroom I’ve taken the original lighting/mains cable back into the loft which will be joined in a junction box and then run my cable from that to the first downlight and then run the second light of the first,the third of the second light and so on untill the end (8lights) the cable I’ve currently got to use is 1.5mm 3 core white flex is this ok to use/upto standards for what it will be being used for ?
Also the lights don’t require an earth so can I just clip the eart cable out the way? Any help would be appreciated thanks
Don't clip the earth out of the way. Leave it intact through to the last light for when you do your EFLI test. Make sure to clip the cable neatly throughout. Ensure you meet manufacturers recommendations regards thermal insulation. Don't forget your IR test just to be on the safe side. Be sure to meet building regs regards fireproofing, sound etc. Jobs a goodun.
I was planning to just run a in and out cable Into the joint box that’s already attached to the light itself and just thought that with them needing to be moved in and out painting the ceiling etc that flex cable would be more suitable than t&e cable as that will only take so many movements of being pulled up and down before it will break? That’s just what I assume lol
crack on !
Flex is ok to use, make sure it is neatly laid in the loft. As Vortigern said about the CPC (green/ yellow) connect it all the way along the route so it is continuous to the end light for testing.
Onto the more serious bit. It’s not easy to make downlights look great without some equipment that an electrician would have with them including the continuity testing equipment to know the circuit is safe to recommission, a laser or chalk line and hole cutters to make it very neat.
If you are going to do it yourself, safe isolation of the circuit and most importantly, please take a photo of the ceiling before and after to show us when you finish - we will then give you a pat on the back or say ‘told you do’.
Be careful.
be aware that different makes/types of downlights require different sizes of holes. some are OK with a 16oz. claw hammer. some need a 5lb. lump hammer, to make the holes.
Ps check it’s not plaster and lathe before you start otherwise read the other thread!
Lol thanks for the help the holes I measured and drilled out yesterday and laid the cable in place to all the holes so going to wire it all up and see how it goes :) should I leave the flex under the insulation in the loft or is it best sitting ontop?
will upload a finished pic (if I get that far!)
I am going to get it checked over just to be sure by an electrician once done but I’m pretty good at a lot of things including electrics so I’d rather have them checked over then have to pay out for an electrician to come and do all the work and wiring up etc and charge me ten times what the lights cost me lol
personally I would not use flex for fixed wiring, it's my choice not to, some will say it's OK to use flex, I guess I was brought up to do the job properly, by that I mean clipping the cable to the rafters, using twin and earth (in this case) cable, more importantly NOT cutting the cpc out.
Reply to led downlighting wiring help in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi Total novi e but have wired multiple light switches previously and survived :) I've bought a nice WiFi enabled dinner switch for a new LED...
Hey all, hoping someone can help with a particularly annoying problem! Have changed a load of LED downlights to the fixed bulb Centorio type (14W...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
