Discuss Led lighting how to connect in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Usual problem,client wants led ground lights in lounge & dining rooms,
Floor will be screed & tiles,how would you connect them,haven’t seen them yet,but they will most probably be pre flexed.
Galv conduit to pots mounted in screed and use Wagos.
You might have to get pots manufactured to suit the fittings you use for ease of maintenance. Might be persuading the client to buy extra spare fittings for future use in case of failures.
Sounds good,will know more when they come.
Reply to Led lighting how to connect in the UK Electrical Forum area at ElectriciansForums.net
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
I'm from Sri Lanka. We have installed LED Floodlights from two different Italian Brands (I can mention the names if wanted) on two different...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
