Discuss led tape light ip rated- clipped not sticky back in the UK Electrical Forum area at ElectriciansForums.net
I used LED Hut for some recently, its IP rated and sticky but I used some 1mm twin an earth clips as well just to make sure, they fitted it pretty well.
Reply to led tape light ip rated- clipped not sticky back in the UK Electrical Forum area at ElectriciansForums.net
Hello, Does anyone know of a Driver for led tape that can adjust the brightness on the driver itself by turning a screw etc ? Just need...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
Hello, I'm new to this and I'm looking for someone to review my wiring diagram. I'm not sure if I need a fuse block because I'm using an XTM...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
