Discuss Light fitting DIY in the Lighting Forum area at ElectriciansForums.net
30min job for an electrician.
diy could take from 30 min to 5 hours depending on your
knowledge,
experience,
and if lacking in either of those 2, luck.
I give up. can't see the spider anywhere.
Welcome to the forum mate.
As above. its hard to say how long it will take to do the job.
Take a pic of the light wiring you are going to swap it with. This should give us more of a clue.
Switch off the power to the lights at the consumer unit before you go messing with it though.
The fitting looks somewhat like a standard style that has not been quite completed before being sold. Usually the various L & N connectors are already pre-joined in some crimp/twist connectors, not all just dangling loose. And usually the large E ring terminal is already fixed under one of the nuts holding the lighting bars/supports, rather than also left dangling. And a bit curious to have each set of wires loosely wrapped with yellow/green earth tape. It all adds up to lots more possibilities than normal to get things wrong.
Reply to Light fitting DIY in the Lighting Forum area at ElectriciansForums.net
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
I made a DIY light fixture by putting some cut-to-size LED strips in an aluminum housing connecting them to a Mean Well DC power supply with a...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi, does anyone know where I can buy a replacement light fitting like the one in the picture? It takes a s15 bulb 284mm and the length can be no...
