Discuss Light removal, with connected neutral in the Lighting Forum area at ElectriciansForums.net
I'm looking to disconnect a two lights from a lighting circuit while leaving the main light connected. I can remove the second switched live to the two lights at the 2gang switch however the neutral is in a Jb under the floor boards somewhere.
Is it acceptable to leave the neutral, earth and disconnect live and cover over?
No. Neutral is a live conductor. It needs to be properly terminated and enclosed.
There are two issues here.
1-safely terminating and enclosing the cables where possible (Quickwire connectors sometimes can be handy for this)
2-ensuring that any remaining live cables are still within safe cable zones once the light fittings are removed. (If unsure google “safe cable zones”). If wall lights this can be hard to achieve but it’s important so someone doesn’t unexpectedly “find” the live cable in 20 years time.
Reply to Light removal, with connected neutral in the Lighting Forum area at ElectriciansForums.net
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
