Discuss Light switch wiring query in the UK Electrical Forum area at ElectriciansForums.net
Hey all.. Newb query but I've tried all combinations and no joy..
I'm refurbing a house and wiring seems to differ circuit to circuit..
I'm changing light switches in kitchen and corridor.. Both wired as found however now lights won't turn off at all..
Both rooms are 2 way and the kitchen switch 1 won't turn off and switch 2 won't turn on or off
Initial wiring on kitchen was com=red l1=blue and l2=yellow and leftovers.. However this now doesn't work and all combos seem to either keep light on constantly or not get power at all..
The corridor switches are upstairs control which works fine... Downstairs control won't turn off light in downstairs passage so constantly on and won't turn off.
First pict is kitchen where 2nd light won't power on and first won't power off.. 2nd pict is corridor where upstairs works fine on n off but downstairs won't power off. Note the difference in circuit wiring
Any hints
It probably won't power off because you have both reds connected to the same terminal presumably one of them is live and one is switched live. Have you removed any links or anything? Also earth the face plate- very important
Thanks very much...
Is it just a case of individually fixing and testing each red... Ive tried that and even with a single red in, when it's on it stays on
No idea what's going on in the first photo, with two reds and a yellow all going into the same non-common terminal. But all that bare copper shouldn't be on show.
In the second photo, the far switch seems to have two red wires going into the common terminal, but nothing in the other terminals. The switch won't do anything like that! Putting one of those reds in an unused terminal on that switch might make it work, but if that's supposed to be a two way circuit, something's missing!
Reply to Light switch wiring query in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
I have 2 kitchen lights, each on its own switch. I would like to re-wire them to where the first switch turns on both lights, but where if the...
