Search for tools and product advice,
Discuss Lumen Method in the Australia area at ElectriciansForums.net
measure the luminous flux ie
Lets say a 85w lamp has an output of 5700 lm and after a few months of service has fallen to 5200 lm
MF = 5200/5700 = 0.9
It will always be less than 1
calcs no worries but guidelines i am not 100%. I would give Thorn or Aurora a buzz on there tech line. Someone will be more than happy to talk to you for 3 hours about it!?!
Reply to Lumen Method in the Australia area at ElectriciansForums.net
Hi, I'm running a 70ft underground UF cable in 3/4 inch PVC conduit to 2 sheds. The sheds are 3ft from each other. I'm just a DIYer enthusiast so...
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
Morning! Would someone please mind checking the big brown book for 1.5mm flat sheathed cable, ref method B, CCC? Page 456 from memory. Only have...
Hi all, I'm wondering if someone can answer this question concerning a wiring scenario. I recently saw on a youtube video - a guy create a...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
