Discuss Main Eearthing Conductor - Fabric ???? in the UK Electrical Forum area at ElectriciansForums.net
See picture below the Main Earthing Conductor is some kind of Fabric?
It’s normally the case that where you see this it is TNS earthing and when the PFC is measured the braid will sufficiently satisfy the adiabatic equation.
If it’s TNS there is no requirement of min 10 sq mm main bonds.
So while you won’t see this example in the On Site Guide it can usually be proved to be compliant.
Reply to Main Eearthing Conductor - Fabric ???? in the UK Electrical Forum area at ElectriciansForums.net
Replacing DB’s with all singing all dancing RCBO’s Problem’s we have now…Existing installation consisted of DB Grd Floor.. DB 1st Floor…Grd Floor...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
